My srs dash board light is on an my horn doesn't work. I believe the ligt an horn stopped working at same time. I looked at the fuses under hood an under dash. The srs and horn fuse are ok. So my question is, what is the problem? Has this happened to anyone else, and if so how do I fix it? Thank you for any help.
Also my ebrake light stays on also, I belive the switch is bad on that, I'll check an if problem with that light doesn't work I'll be asking how to fix that as well. Hope to hear back soon from someone with suggestions....
