Hello everybody - I'm a noob to the forum - been lurking for a while and used some advice I found here. I had hoped my first post to be one where I brazenly showed off my awesome handiwork...but instead I've got a real mess on my hands.
I think I know what I need to do to fix it -but i need advice to find the smartest way to go about doing the repair. Some history-
I did a timing belt replacement/water pump job on my '93 Accord LX (150k indicated) and got all that done per the procedures found here (TDC etc). I didn't have any real issues and everything was aligned. To me, the reassembled new timing belt seemed to lack tension - the springs didn't hold it very tight, but this being my first one, I didn't know what to expect. At the same time I replaced the o-rings on the plug holes since they were leaking oil pretty badly. Everything was torqued down per the manual. Or so I thought.
I turned the motor over several times by hand - there was no binding or unhappy noises, the alignment marks would still line up, so I completed the reassembly. I started it up, and it fired right away and went to high idle (it's cold here) - ran fine & sounded great as it warmed up. When it came off high idle, the idle started to bounce. I attributed this to the fact that I hadn't burped the coolant system yet. I did that, and it didn't improve - as it got warmer over the next 3-4 minutes, the idle dropped again, this time so low that it would stall.
It would start right back up - but I had to keep my foot in it around 1k rpm so it would run..and it sounded fine. Suddenly, it just shut off. I attempted to restart - it wouldn't catch at all.
Upon investigating, I found it had no spark. I ohmed out the coil and according to the book it was out of spec, so I shotgunned it. Tried again, still no spark. At this point I was convinced I was barking up the wrong tree so I removed the valve cover to inspect - and was stunned to see that the cam sprocket had sheared off the end of the cam. After a change of pants, I took a closer look - I don't know if I under or over torqued it - but the sprocket is sheared right off, with the bolt still in place. There's no other damage visible at this level of disassembly.
My question is- what's the smartest course of action to get it back on the road (besides, you know, just not screwing up in the first place)? I'm thinking that I should install a salvage cam & do a compression check - or would that be a waste of time & I should just get a salvage head and be done with it? Or just put the car out back and make it a giant birdfeeder? That's a viable option.
