Brake Lights Not Turning On
    So after redoing my seals for my trunk, my tail lights will not brighten when I hit the brakes.
    It is not the brake light switch because the rubber piece is not there.
    Can anyone help me out?
    I think you need to start by telling us exactly what you did and what troubleshooting you've performed since. If the rubber stopper on the brake pedal for the switch were missing, your brake lights would be on all the time.
      Buy a DMM and check to see if you have voltage on the brake light pin when the pedal is depressed.
      YouTube Clicky!!
        Sorry the rubber piece is there, my bad and the only troubleshooting I've done is the brake switch and someone mentioned a fuse. However, which fuse is the one for the brakes?
