I have a 1990 accord sedan f22a1 manual trans and the problem im having right now is with the car not wanting to go into gear while running. When the car is off i can put it into gear and start the car but when i have to shift the trans has a hard time going into the next gear and will sometimes either grind or not go in at all. When coming to a stop i have to i have to take the car out of gear or it will stall itself out even with the pedal down engaging the clutch.
My first thought was to replace the slave and clutch master cylinders so i did along with changing the oil in the transmission. Even after doing all of this im still having the same trouble. I was told the clutch and throw out bearing could be bad but the clutch doesn't slip at all & im not hearing any noise indicating that it would be a throw out. Im going to take the trans out soon but untill that happens is there anyone here that has experienced similar problems and could help or give any suggestions?
Thanks.
Thanks.
