Does anyone know the cause of the on going issue of the print board on the cluster burning on the door indicator part and a few other spots . I have been to many pull apart and 98% of them are burned in same spots ? I'm in need of a 93 auto cluster none sport shift
Gauge cluster burned print board ?
I believe the cause is more corrosion than burning. I purchased my wagon in Pensacola and immediately had problems with the speedometer and odometer because of corrosion on the printed circuit board. A replacement from a yard down there was clean where the original was corroded, but had some corrosion elsewhere (it was also from a sedan), but everything worked when I installed it (speedo was off, put 130 mph speedo in). I eventually had problems with the temp and fuel gauges because of the other area of corrosion.
You need to find one from a dryer, less salty environment. You should also be specific with what you need. DX, LX, EX, SE? 2dr, 4dr, wagon? It makes a difference. Sounds like it is an auto; manual gauge clusters are different as well.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
