So I have spend a week now attempting to get my accord timed ríght no matter what I do it still seems to run like crap I cannot get the balancer pulley off in order to see if there are marks to be lined up for the crank timing so I have been doing it the old fashioned way with a screwdriver in cyl 1 and watch it go up then I line up the marks on the cam slap the belt back on and try it never seems quite right runs really rough and has no power never purrs... looking on the web I found someone talking about being able to use the timing marks in the inspection window for the tranny when I pull out the little rubber plug I can see the flywheel on the engine side of the window there is a nub that looks like as to line something up with on when I turned the motor to tdc there are three littke marks on the flywheel ( , / , this is xort of what they look like but theyre straight ) the are realy close to the nub I mentioned it looks like if I bring the crack to perfect tdc they would line up great after doing so I looked at the cam again and its slightly off a tooth or so does anyone know if I can use these marks as tdc marks to get the timing right on and after just adjust the cam and it ahould run good? Any help appreciated this has been a nightmare for me and its our familys only car.. thank you
Btw: 1990 honda accord (ex?) F22a4
