wiring help
    wiring help
    Hi I have been following this forum for years but just signed up me and 2 buddys have started puting f22a motors and trans on back of rail buggys and I'm lost on how to wire after market fues and relay boxes up in place of factory box under dash and hood we want to put marine boxes so the are water proof
    sorry I cant be of any help .... buttttttt have you got any pictures of these beasts you speak of ?
      Yes I do but how do you post pics here if you google 2.2 rail build I have pics on honda-tech
      And I'm building 3 of them and once the bugs are worked out they will be boosted
        You link an IMG link, just like any forum.
        Upload your photos to photobucket or something, the the IMG link, press the small image button in the quick reply link (yellow background, With mountain), delete the HTTP:// that's already inserted and then paste your link.
        sold! But here's my build thread for those interested.
        http://www.cb7tuner.com/vbb/showthread.php?t=206864
          [IMG][IMG][/IMG][/IMG]
            [IMG][/IMG]
              [IMG][/IMG]
                [IMG][/IMG]
                  That's all I got for now will be making rear trailing arms with accord hubs and running stock prelude axles and if the room is there will be running air bag suspinsion on rear and makeing a arms up front with coil overs
                    just take the "box from under the hood" and attach to buggy.
                      that's what I was going to suggest cool rig
                        That was the original plan but where we ride is a lot of mud and water we got to go threw so wanted a marine style fuse box to water proof it I have been looking at diagrams and I also know that chase bay race harnesses run 5 fuses and 5 relays I only really need the bare minimum to run the motor and what is confusing me on the diagrams is I see where the wire gos in the fuse box but not out and how to bypass the intagrated control unit on the under dash box and thanks for the complaments we are about to start bending some more tubing and seting the motors in the other two rails I will try and keep you all updated that are interested
                          And just making sure are you saying the under the hood box is all I need to operate the motor and if so what about the ecu fuse under the dash
                            Power and fuse IG1 and IG2 on the ecu. That's pretty much all the 12v power the ECU takes. I'll get you those pin numbers and wire colors for you later.
                            Edit: well there's the main relay and fuel pump
                            YouTube Clicky!!
                              That would be a big help thank you
