Thank you rilas we are hoping they will fly plan to put about 350whp down lol trying to prove you don't need to buy a 20k rzr to domanate the woods
wiring help
Why not just mount the fuse box and Ecu on the top rail above the motor? A little ghetto but if you get water up that high I'm sure the buggy and motor are lost at that point. Awesome build by the way, reminds me of the guy who was building a trike with the f22, sadly he never finished it.~Nick~
We have talked about a few ideas of where and what to do with the wire harness. We are leaning towards building a standalone harness just to make a clean install. I know it don't look the best now but will be painting the frames when we are don fabing everything. Thank you for the interest we are doing this because so many people told me it can't be done and don't worry it may take some time to finish but it will be done not only one but we are building 3 of them.
Why not just get a Microsquirt? You're going to be tuning it anyways and it would cut down on the wiring immensely.
http://www.ebay.com/itm/MicroSquirt-...1U06VK&vxp=mtr
Plus a Marine fuse block.
https://www.amazon.com/dp/B001P6FTHC...741AS4RZ&psc=1
How to wire and configure it
https://www.diyautotune.com/support/...rt-your-honda/
The Microsquirt case is designed to be weathersealed with a bead of silicone. Actually thinking about it you could just get the Microsquirt itself ($299) and the ampseal connector and use the stock engine harness, just re-crimp it to the Ampseal connector for the microsquirt. Just a thought. Tuning software is free or nearly free, and it does have an autotune setting as well.Last edited by Accrdwgnguy; 01-19-2017, 09:14 AM.
I am not a tunner I am going to mess with a vafc hack on my first motor but will probably end up with a chiped p28 and have scott brooks tune it or turbo dave. I have looked at micro squirt for my 5.3 mustang but wouldn't know where to start with mega squirt on a honda do you still run distributor or coil packs with it.
Well I think we got are wire harness problem solved. I talked to the cat over at motor sports wiring solutions he is going to be doing a full stand alone harness with a water proof fuse box and rocker panel. The best part is he is doing it for half the cost of what I was quoted by rywire. They seem to know there stuff so check them out if you need any thing I don't think there is much they can do. I will post pic of there work
