Leaking issue
    Leaking issue
    Anyone have an issue of leaks coming back a short time after they have been replaced. (oil-pan gasket)
    Yes but there's always a reason:
    1 - Unclean gasket surface (did you remove all traces of old gasket and grime before installing a new gasket?)
    2 - Damaged sealing surface (did you gouge the sealing surface with a scraper when trying to clean it?)
    3 - Incorrect torque value. Note that more is not always better in this case. Sometimes overtorquing a gasket will cause it to fail and leak.
    For what it's worth, I replaced my oil pan gasket and it weeps a little bit still. Probably scratched the mating surface.
    1992 EX, 306,000 miles - Track toy - M2S4, H23A1, ST rear swaybar, Wagon brakes, GC coil sleeves, KYB AGX dampers, Stoptech pads, Toyo Proxes R1R, 2.25" exhaust
    Stock F22A6
    VIR, 5/22/2016: https://youtu.be/eR5-ylSPsxk
    H23A1 powered
    NCCAR, 9/4/2016: https://www.youtube.com/watch?v=TI5WpxGrEpE
    CMP, 10/16/2016: https://youtu.be/DOqoe5f-GLY
      There's also a torque pattern for pan gasket R&R. Get some Hondabond, and do it by the book.
        I had one early in my CB7 career that a dealer replaced and left one of the metal spacers from the old gasket on the stud on the underside of the block; it created a huge gap when the new one was installed. I was lucky enough oil remained in it to get it home (where I realized it was leaking a LOT).
