Hi all, new to the forum, and new to Honda in general...
So let me start at the beginning...
About 2 weeks ago, I bought a 91 Honda Accord Wagon for a work car. Car supposedly set for approx. 1 year under a carport on a concrete pad. Got the car home and the started looking into what I needed to fix to drive it.
So far I have discovered the car doesn't want to pull itself in D4 or D3, but will pull itself just fine if I manually shift to 1st or 2nd. The power windows don't work. The instrument cluster lights, headlights, and park lights only work when the brake pedal is depressed, the radio doesn't play, the antenna doesn't go up or down but it's motor runs. Last but not least the engine didn't want to idle when I brought it home,after running it a few times this seems to have gone away though.
This thread is about the trans though...
Like I said above, the car doesn't seem to want to pull itself if I select D3 or D4, but if I manually select 1st or 2nd gear it seems to pull just fine.
I think it is worth mentioning I have not drove this car on the road yet due to it having some issues I want to sort out before I start "driving" it. But have moved it around the yard and driveway (which is about a mile long).
The D4 lights is staying illuminated at all times unless I put it into D4 as well.
Upon doing some research I concluded that the TCU was bad, and set out on a search for a parts car with a good TCU. Found a 92' CB7 in the middle of a old strip mine on craigslist, went and checked out what was left of the car, paid the man, and drug it home (not knowing whether the TCU was good or not.) Today, well yesterday now... I got up and pulled the TCU out of my CB9 and the TCU out of the CB7 and opened them both up. The CB9 TCU was definitely fried and the CB7 TCU appeared to be fine, so I removed the ECM/ECU from my CB9 tray and hooked it and the CB7 TCU up loose in my CB9 floorboard. (No fix) D4 light still on solid. (I have not driven car since replacing TCU as tires and rims off my CB9 are on the CB7 on the trailer ATM...) also swapped the cruise control module because it was hanging loose and was marked AT (not knowing exactly what it was...and AT screams automatic trans to me lol) (No fix, swapped back)
I am planning on removing and testing Shift Solenoids,and wanted to know if anybody knew what values they were supposed to read if good.
If anyone has any other suggestions on this issue, I would be grateful for the assistance.
Car is a virgin (bone stock), and I plan on keeping it that way until I get it 100% fixed. That being said it is also going to be my work car and I don't want to put a ton of cash into it. I'm driving almost 80 miles a day to work and back home and my 08' F150 isn't exactly easy on gas lol. So the quicker and cheaper I can fix this the better.
Thanks in advance ,
Cole
Thanks in advance ,
Cole
