Naw it's red fluid in pretty savy when it comes to the engine but really know squat about transmissions I e been watching erick the car guy trying to get some pointers
transmission fluid leak
Is item 1 the "cover" you're talking about? Item 20 look like the pins you're talking about? Know if any of the seals at that end of the engine have ever been replaced?
He him no t trying to get extra posts but I'm reading your q's after I post the reply but no it's a maybe 1 1/2 inch pin with no threads on it not sure exactly what the thing is for but I'm guessing it goes on that cover somewhere because it's missing some fasteners or something of the sourt
But that is the cover you say the fluid is leaking from the bottom of?90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
What is the diameter of the pin? I can't think of anywhere a pin that long is used. 20 is not the pin you're talking about, but are some of #20 missing for the lower cover?90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
Yes there are empty wholes in that cover so I'm sure there are pins missing as far as the pin in trying to explain it just fell out one day I heard it hit the floor I figured wherever it came from it was there for a reason but couldn't figure it out it didn't seem to affect the car at all so I just left it alone...maybe I need to recheck under the car to see if I can better pinpoint the leak but I'm sure it's trans fluid tho
Figure out how many of those bolts you are missing and get them from a salvage yard or they are still available from Honda. If that cover is not bolted down it will wear against the back of the pulley or the belts.
I don't understand how transmission fluid can get all the way over there. Just thinking out loud: Is there trans fluid on the transmission where the axles go in? The left axle will tend to fling it all over the back of the engine. Do you park with the left side of the car down where it could run along the lip of the oil pan to the left side of the block?
Is there a lot of fluid on the inner axle boot or even on the axle shaft?90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
So the pin has a hex head (10 mm), but no threads? Is #19 missing on the upper timing cover?90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
