mi carro no enciende
    hola amigos de la comunidad.
    necesito su ayuda.
    mi carro no quiere encender.
    enciende las luces del tablero pero al darle a encender no hace nada.
    es como si no le llegara corriente al relay principal.
    espero que me ayuden con este problema...
    Per Google Translate:
    Hi, community friends.
    I need your help.
    My car does not want to turn on.
    Lights the lpuces(?) of the board but to give to ignite it does not do anything.
    It is as if the main relay did not reach the main stream.
    I hope you help me with this problem ...
    Response/Respuesta:
    Does this mean the dash lights come on, but the engine does not turn? Or that the engine turns, but does not ignite?
    Google Translate:
    &#191;Significa esto que las luces del tablero se encienden, pero el motor no gira? &#191;O que el motor gira, pero no se enciende?
      si. las luces del tablero encienden y el motor de arranque se mueve pero el carro no enciende
      es como si le falta chispa para encender
      yes. The lights on the dash light up and the starter motor moves but the car does not turn on
      it is as if it lacks spark to ignite
        yes. The lights on the dash light up and the starter motor moves but the car does not start
        It is as if he lacks spark to ignite
        Assuming your cam is still turning with the crank, you need fuel and spark. Do you have fuel pressure? Do you hear the fuel pump run for 2 seconds when turning the key to the "on" position? Do you know that you have spark?
        Suponiendo que su leva sigue girando con la manivela, necesita combustible y chispa. ¿Tiene presión de combustible? ¿Oye que la bomba de combustible funciona durante 2 segundos al girar la llave a la posición "encendido"? ¿Sabes que tienes chispa?
          ese es el problema. que la bomba no arranca. tampoco pude ver chispa en la ignicion
          that's the problem. That the pump will not start. I could not see spark in the ignition either
            How many miles on your car? If you don't hear the pump running, it is most likely the main relay. You can either replace it, or remove it and resolder it.
            As for ignition, check that all the electrical connectors to the coil and distributor are good. Check that the ground wire to the underside of the thermostat housing is well secured (maybe even take it off, clean it, and reinstall). How old are your plugs and wires? What condition is the distributor rotor and cap in?
            &#191;Cu&#225;ntas millas hay en tu auto? Si no escucha la bomba en funcionamiento, es muy probable que sea el rel&#233; principal. Puede reemplazarlo o quitarlo y volver a colocarlo.
            En cuanto a la ignici&#243;n, compruebe que todos los conectores el&#233;ctricos de la bobina y el distribuidor son buenos. Compruebe que el cable de tierra en la parte inferior de la carcasa del termostato est&#233; bien asegurado (tal vez incluso qu&#237;telo, l&#237;mpielo y vuelva a instalarlo). &#191;Cu&#225;ntos a&#241;os tienen sus enchufes y cables? &#191;En qu&#233; condici&#243;n est&#225; el rotor del distribuidor y la tapa?
              Hola amigos encontr&#233; el problema. Era la colecci&#243;n del rel&#233; principal que va a la bomba de gasolina que estaba desconectado. Ya enciende perfecto... Gracias por su gran ayuda.
                Swap out your main relay, theyre cheap and control fuel pump, ignition and various other systems needed to start the car and keep it running
                  Que bueno que lo pudiste resolver. Si sucede otravez en el futuro cambia el Main Relay porque se da&#241;an frecuentemente en nuestros autos.
