I bought a 93 base model accord back in november, It had been sitting under a tree for about a year unused. When I took it home I noticed the antenna didnt open fully, I took the power antenna assembly out, and got the mast out, I had to put vice-grips on the end and hammer it for ages until each section finally opened up, I oiled it up and put it back together and it worked great until now, it stays partially open, is there some way I can stop it from getting stuck all the time? perhaps something other than engine oil would work better? Some sort of grease that doesnt attract dirt, idk, how do you guys keep it running smoothly?
Power antenna keeps getting stuck partially open
I would suggest installing a new mast; I have had good success with masts from Bridgewood Motorsports, www.antennamastsrus.com. The new mast comes with installation instructions. There are a couple threads in the DIY section, but the pictures no longer work. I used to rebuild them (for fun and not so much profit); I guess I should do another and prepare a new DIY. I think is it best to just keep the mast clean, almost any lubricant will attract dirt. When I get gas and clean my windshield, I'll use the paper towel to clean the mast as well - hold the top end to support it while you wipe up and down.
It is also possible that the internals of your motor assembly are very dirty and the teeth on the mast drive belt are worn. There is a small pin in the motor assembly that keeps the drive belt in contact with the drive gear - this pin wears and allows the belt to slip on the gear. The pin can be pulled out and rotated to an unworn spot to correct this.
Edit: This thread has some photos and info about cleaning the insides of the antenna assembly: http://www.cb7tuner.com/vbb/showthread.php?t=166674Last edited by Fleetw00d; 03-11-2017, 12:42 AM.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
