1990 Automatic Transmission with roughly 85,000 miles
My passenger side CV Axle goes out the other day so I replace it. A day later my transmission will rev up and struggle to shift. I need to release the gas peddle let the RPMs go down and it will shift. I have noticed if I don't gas it and drive slowly from 1st-3rd it will shift ok, but anytime I put a little bit into it, RPMs raise quickly and will not want to shift. My Shift/D4 light is NOT blinking. After testing and checking the list below I am still having issues. What are your thoughts?
The things I have tested/checked
I thought it would be smart to drain the transmission fluid so I did. When it was draining it was very black and a couple little chunks came out, I tried taking some photos. Do you think I should fill it up with some HONDA transmission fluid and see how it shifts, or do you think the damage it already done? I also have taken out my passenger side CV Axle to make sure it was in correct. I inspected inside the tranny where the CV Axle slides in, looks good to me. Anyone else see anything out of wack there?
- Jumped blue pin: Checked for codes, but nothing comes up
- Fuses: No fuses were blown
- Transmission fluid: The fluid was perfect level, clear red, smelled good
- TCM: I opened it and noticed resistor R41 burnt. I had R41, R42 and C28 replaced
- Shift solenoids: working condition
- Speed sensor: had an extra NEW one so I replaced
- CV Axle: Wanted to make sure it was all the way in and it was
