Car is over heating when idle. Temp will go back down while driving. I have replaced the thermostat, coolant temperature switch, coolant temperature sensor and upper radiator hose. I need help with diagnosis. Any ideas.
Over heating trouble shoot
If it goes up relatively quickly when stopping, and drops quickly when you start moving again; it could just be that the coolant is low. Was coolant low when it was overheating? Did you fill and bleed the system correctly after the work you did? I have found that raising the front of car as much as possible when filling the radiator helps. Fill it to the top, open the bleed screw on the thermostat housing until you get a solid stream of coolant, close the bleed screw, then make sure the radiator is full again before putting the cap on.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
