Auto door unlock ?
    Auto door unlock ?
    92 Accord EX
    where is easiest place to tap in for door unlock\ lock ??
    wire color and location ?
    does it take positive or negative to unlock \ lock ?
    The wires for the door unlock and lock are behind the driver’s kick panel. Unlock is Black w/ Red stripe, Lock is Black w/ a White stripe. I think this a 2 pin connector that is taped to one of the larger wire looms in this area if my memory is accurate.
      Yep SSM is correct. The loom is under the carpet on the bottom of the fuse box.
      ~Nick~
        Ok thanks !!
        anyone know how to activate it ?
        also if installing an alarm will i need separate relays to lock\unlock or can i tap into the relay already there ?
          So you're tapping into the wires of the car, not relays. Your alarm kit should of come with a detailed manual. If you don't have one, try to get one as there are specific wires to tap.
