My ‘90 accord had this weird wobble when driving down the road. I can feel it pull to the right a little, then it stops for a second then it happens again over and over. It’s still very drivable but it’s just a pain because I have to hold the steering wheel with both hands if I want the ride to be semi smooth, does anyone know what could be causing this? If it helps I think the suspension on the front left tire is shot. Thank you in advance
Weird Wobble While Driving
Size9zombie i replaced the front right tire because it got a hole but even before it had this problem. I haven’t jacked it up yet to check though. Any ideas on what part of the suspension might be messed up?
Tie rod ends, ball joints, control arm bushings, wheel bearings, radius rod bushings, steering rack. While you're looking, check for broken springs; typically occurs where the first bottom coil leaves the support. Also check if the brakes are dragging.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
