Intermediate shaft????
    ok not sure if this is the right section but imma give it a shot. im working on five speed swapping my 92 and i have all the parts except the intermediate shaft. i cant find it on any auto parts store website and all the ones i can find anywhere else online are extremely expensive and i cant tell if theyre even the right part. do i need to get an intermediate shaft when switching from auto to manual or will the automatic drivers side cv shaft fit? also will the intermediate shaft from a 5th gen work? i really need to figure out a solution to this because i wanna get this car driving again but i am at a dead end. any help is greatly appreciated!
    The half shaft for a 92 is common to 91-97 Accords. https://www.hondaautomotiveparts.com...w0LWdhcw%3D%3D
    As far as I know, you need the half shaft for use with the manual transmission.
    • slow.cb7
      slow.cb7 commented
      Editing a comment
      thanks man ill go pull one off a 5th gen tmr, there was a 4th gen when i went to the yard today but it was not in good shape and the axle nut snapped my rachet
    You can not use an automatic shaft on a manual transmission. You need to get an intermediate shaft. Your best place to get one is from a junkyard. Make sure you get the 3 bolts that mount it to the back of the block as well.
    ~Nick~
      You can also use an intermediate shaft from a prelude and use the prelude axle.
        i tried this and always gave me problems i auto to manual swapped mine w prelude trans and gave me knocking sounds from axle
        used accord half and axle and drove perfect!
