I'm pretty new to this site so I hope I'm posting in the right section.
I have a 1992 Accord EX 5 speed, and my cruise control has recently stopped working. The cruise main light is on when the button is pressed, and the green cruise light in the gauge cluster comes on when I press SET, but the cruise control does not actuate. The 7.5a cruise fuse is good. I do have vacuum pressure, no vacuum leaks. It's not the clutch or brake switch because the light in the cluster wouldn't come on if that were the case. I used the troubleshooting section in the Honda service manual to check various pins on the cruise control module connector under the dash, and everything checks out. Not too sure what else to check, besides checking for voltage at the CC actuator connector in the engine bay with the wheels moving, which I guess would rule out an open wire somewhere.
