ok i have a 1991 automatic accord now on the shifter theres a button that you push it states sport or normal and on the cluster it has a light with a box with a s in the middle well the light sometimes flashes and it shifts fine and sometimes it stays on and wont shift is it a sensor or is my trany going out?
help me
Its stating that there is a problem on the tranny side. You need to pull the code and tell us what it is.
Pull up the passenger side carpeting, and read the number of blinks from the tcu's led.
It states you need to search "sport mode" because its been covered 20395734975 times...
Disregard females, acquire currency.
My 2003 Nissan Maxima Members Ride Thread
DIY: HOW TO POST PIC(S)
Lowz is right....like 10 threads on this alone....here is the best one i could find right away! GL!!! I hated that fucking button in my dads 90-91.
Clicky Clicky!
The transmission control computer is a known problem on these cars. Pull the codes and see what you get but the TCU is more than likely failing. A sensor or shift solenoid will also cause this but it usually will not come and go.
Here is a good thread on the subject,
http://www.automotiveforums.com/vbul...d.php?t=441643
Here is how to pull the codes,
http://home.earthlink.net/~michaelpk...owTo_Codes.htm
Mine was the TCU and a rebuilt unit repaired it.
The 90 Accord 4DR Sedan my son and I are building.
I was gonna post how to pull the codes, but he beat me to it. I'm not sure if the service connector needs to be jumped to check the tcm codes, I can't recall from memory, so I'll go look it up.
Yes, because a 5spd does not need a separate ecu to control the way how it shifts since you are the one in control. However, prepare to incur add'l costs as a 5spd swap can be costly depending where you go, otherwise if you do it yourself, you will save yourself big change.Originally posted by boriQuestion If I Swap To Standard 5 Speed Is That Worry Over For Me???? Meaning Will I Ever Have To Worry About This Again2010 Toyota Camry LE 2.5L - the most boring car ever
2002 Impreza WRX - TD05-16G, 178K miles, 30mpg hwy
1993 Accord SE - RIP 10/2000-07/2013
