For all those with idle problems
    Originally posted by greencb7inkc
    Nothing?
    I made 23mpg this last time and im willing to bet that if i didnt have to sit for 5 minutes almost everytime i started my car, i wouldve been able to squueze out another mpg or 2.
    I never let it sit more than a minute or so to warm up in winter (and I'm in northern IL,) just drive it easy first couple of minutes if you're worried about warming it up. Any longer and you're just burning gas.
    IMHO of course.
      Thats what i wanna do. Im just worried of any consequences of not letting it come to 750rpm.
      Maybe i'll experiment with it for a week and i'll let it sit for a minute or two and go. Then i'll see if it runs any different using that technique.
      Originally posted by Jarrett
        this works great saved me alot of time and money it took me two minutes thanks alot
        http://www.myspace.com/alliance_nwracing
        cb7 NOW FOR SALE!!!
          Question, could a loss in tranny fluid contribute to very rough idle in P, D or reverse? cause I think I have that problem
          My Black "H"
          AL Meet!?
          //Secret G2I Lover, Shhhhhhh! //
            I'm seeing something very much like this. I tightened the fast idle, and that fixed the majority of my issues, but in drive or reverse it's still got a VERY rough idle. Almost down to 400RPMs and it feels like the car is going to shake it's self to pieces. I've tried messing with the throttle cable, and I've adjusted the idle screw on the bottom side of the throttle body to no avail. Could a gap between the TB and the intake be causing this? When we put this motor in the car, we had to switch the TBs since the motor came out of a 5 speed (yeah, I've got an auto ), and the gasket was a little ate up. Everything is snug, and I can't find a leak in the vacuum system anywhere else. Let me know what you all think!!
              This should be arranged and put in the sticky section.
              My RIDE
                bummpp cuz i needed this information
                  In the fast idle i just tightned the " white thing" that circles the valve idk how's it called but after that everything came back to normal.
                    seafoam?
                    MY CB7
                    FULL part out thread:
                    http://www.cb7tuner.com/vbb/showthread.php?t=204494
                      Originally posted by DaBzzMn View Post
                      Hey guys, I wanted to post this because i am tired of seeing the same thing over and over, "Help idle problems" or "My idle is revving back and forth" I have looked up a picture to show you all on how to fix the problem. Down below is a picture showing the intake manifold.
                      If you look at group #8-has numbers 3,9,19,26- thats is whats call the fast idle valve. As a honda tech standard on paper this is how you correct the problem.
                      1) Start the engine
                      2) remove the cover of the idle valve by the two screws
                      3) Push your finger on the valve seat area-the cone shaped object inside- and make sure that there is airflow with the engin cold
                      * If not, replace the fast idle valve and retest
                      4) Warm up the engine (cooling fans come on twice)
                      5) Check that the valve is completely closed. If not, air suction can be felt (by putting your hand over the top) in the valve seat area.
                      * If any suction is felt, the valve is leaking. Replace the fast idle valve and recheck
                      To help out even further, if you having a surging problem there is a ring around the air bypass valve. turnit to the left to stop the surging.
                      Thanks
                      Anton
                      Where is the Air Bypass Valve located at?
                      LIVE FREE OR DIE
                        I Cleaned the IAC valve and my idles great now!
                        IridiumCore
                        HCK-The Beginning
                        Your drunk she doesn't look that good.
                          A good tip to get tight screws off enstead of using vise grips is... Before you have completely stripped the screw, just get a hammer, put your screw driver on the screw and lightly tap the top of the screw driver... thats what I did, before it I was stripping the screw. It was soooo tight that I was kneeling on my engine with all my body weight on the screw and still nothing... Then I gave it a "little" tap with a screw driver and... Presto! its loose. And, Tighteningthe white peice dosnt mean your problem is solved, it could be hideing the realproblem... just a tip. Thanks- Garrett, who also has an ideing problem...HAHA
                          _____________________________________________
                          2 year ASE Certification/Auto Technician Degree completed
                            Finally got my idle problem fixed. Checked everything, cleaned everything, checked for leaks, pinched hoses, bled coolant, nothing. Then I re checked the FITV and it wouldn't seal up when at NOT. Replaced and re set idle and wha la I now have a normal idle. FINALLY.
                            LIVE FREE OR DIE
                              I tightened the white peice for the FICV and it kicked my idle down but didnt fix the problem... Mabey i'll try the FITV...
                                Separate from above but definitely pertinent, I've been trying to track down an idle surge for several months now. I tried the above, as well as replacing a bunch of components.
                                I finally fixed the problem last month when I replaced both intake manifold gaskets. The gasket between the plenum and the runners was the culprit.
