short shifters
    short shifters
    i know theres short shifter adapter and short shifter stick.
    does it really matter which one i get,
    if i get the adpater the stick will b same length,
    or if i get the stick it ill jus b smaller and faster shiftin
    any suggestions guys
    If you buy a shifter like the Yeamans17 one, it will have a reduced throw and reduced height.
    The P-spec is shorter in height and has adjustable throw length.
    Both height and throw matter as far as the feeling in shifting, but a shorter throw will have a larger effect than a shorter height.
      search and you will find one that you can make your self for less than 4 dollars.... I made one it it wrks awsome......
        why cany u jus tell where 2 search cuz i dont no where 2 start i tried the search in cb7
          i just looked for it and can't find it anymore something happen to this site it is alot dif then it was like a month ago sorry!!!
            http://www.cb7tuner.com/vbb/showthread.php?t=46210
              Thats the one just ugrade to grade 8 bolts and some good washers.
                i dont get wat he changed tho like the rod or something he didnt have b4 and after pics
                  just buy a short shifter from yeamans17, you'll be glad you did.
                    He's using the stock shifter, the ONLY thing he added was the pictured pipe clamp that allows him to raise the pivot and keep it adjustable. You could raise it as high as it will go before it hits the center console, and that's if you're running a center console, if you aren't, you could raise it even more.
                    I would not get a short shift adapter, there's alot of extra unnecessary material there that doesn't allow the pivot to be raised alot. The pipe clamp itself is very small and doesn't take up alot of room under the console, thus you can raise the pivot more.
                    I'm using a 4th gen prelude shifter and shifter plate, and the factory shift cable bracket was cut off and rewelded as high as it would go (1 5/8") before the cable hit the bottom of the cupholder tray.
                      x2
                      he makes some quality shifters
                        No matter what you do and what you get, all a short shifter does is change the location of where the cable mounts to the shifter. Change that, change the throw. Once you put a knob and boot on it, it's invisible...
                        So either go with a DIY clamp or bracket, as found in the DIY forums, or buy a modified shifter from yeamans17. The modified shifters are good because the bracket is welded on... so the chances of it failing are less than the bolt-on things that can come loose over time. I don't know if yeamans17 cuts the shift lever itself to make it shorter (as fushigi RES did back when I got mine... same concept), but I'm sure he could if you asked. The throw is what matters most, though.
