Ok, earlier today I was driving to work normally and then out of nowhere when I stopped at a light everything was normal. But when the light changed to green, I went to speed up but nothing was happening. So I switched to N then back to D4 and it engaged, so I was like ok no biggie, just a glitch. WRONG!!! After about 10 secs of good acceleration, it joggs like it cant shift out of first. So I tried shifting to N and back to D4 but nothing happened. When I came to a stop with my hazzards on I tried to accelerate again, but nothing was happening. Its like I have to let my car sit for like 1-2 minutes for my tranny to get any movability, is it low fluid or is it my torque coverter going out???
Help..... Asap!!!
possible tranny. if your s light is flashing or your check engine light is on, I would check the codes first before saying that it is the trans.
Ok, just drove my car home just now, everything was fine, but I guess after the tranny case warms up a bit, it starts to slip. I check the fluid before I started to leave and its full so that is fine. ANyone have any idea's, Module, transfer case going out, shift positioner,...........anything???
Ok just did the check for codes right when I got home from work, and it threw a 31 on the ECU and 14 & 15 on the TCM so...........
ECU:
31 means its the A/T FI Signal B high/low input, defective AFSB line, not sure what that means but ok.
TCM:
14 Linear (line pressure control) solenoid open or shorted, Clueless
15 Kick down switch circuit shorted, yet again clueless
Now anyone wanna help me out with this, I need my car up and running soon, got a few meets to attend to, and a dyno run to do to determin my current baseline before any mods. I never had any a/t fail on me except this one(owned about 5 of them, excluding this one), and same goes for m/t(never had a failure, always replaced clutch in due time).
code 15, if your tranny is acting wierd, most likely it is a mechanical problem. if your tranny is not acting wierd, then it is an electrical problem. so it sounds like you have a machanical problem. replace your trans to start. also for code 31, and the other one, it all sounds related to eachother. save your self the hassle of finding the problem, I advise you to replace the tranny. to start. anyone else has any suggestions before he goes replacing the tranny??
Bump.................I wanna get this thing taken care of, got a dyno meet comin and I wanna make it plus I wanna drive my car lol I love it too much(even though its been only like 3-4 months or longer that I have it for. Plus its the car I always wanted to get cause of the aftermarket support)
that is why it seems more like a line pressure problem instead of a solenoid or valve issue. if that torque conv. is messed up, most likely it spit some metal particles into the tranny already causing it to throw all those codes.
