ok so yea at idle my rpms bounce and cylinders one and two do not fire despite having gas and spark. the car is a 92 accord with a 99 h22a4 swap. i am running a p13 ecu, as well as obd1 injectors. it has a 98 dizzy atm but i am getting an obd1 hooked up. could that be the cause?? the car performs perfect at high rpm so i tend to think its not a mechanical problem but i am stumped.
bouncing idle
how do you know the cylinders aren't firing? did you check your dizzy cap?
In my experience...the bouncy rpms are caused mostly by 3 things...'
low coolant level, and or a bad thermostat, OR a bad sensor in the thermostat housing. I think it is called a thermo fast idle sensor. but don't quote me on that.
also vacuum leaks can cause a ROUGH idle.
as for the cylinders not firing....check your plugs, wires and dizzy cap?
getting spark and fuel to the cylinder, dizzy is good, just obd2... this happened with the last engine i had in there so it makes me think its not mechanical and i just find it hard to believe the fitv on both cars was messed up... the engine before started doing this sometime after i replaced the dizzy. i cant remember if it happened right after that or what as this was a while ago.
You need an obd1 distributor/ecu...
yea the obd1 distributor did nothing so i sent it back, but the bouncing idle stopped after it was driven about 30 miles... it is still missing at idle... cant hear it very well when in drive as my exhaust is kinda loud. but it feels like it is hitting on all cylinders. the spark is good and their is gas, i just dont know why it wants to miss... any help guys???
Air, Fuel, and Spark
You say you have spark, and fuel, then the only thing left to check is your air intake. If for whatever reason cylinder 1 & 2 aren't recieving their air charge at idle, then you wouldn't have combustion in those two cylinders.
Personally i'd check your ignition timing, just because you have spark, doesn't mean its sparking at the proper time for combustion.
SUMMONING ALL HONDA GURU'S (A bright spotlight shines on the clouds, with the shadow of a honda symbol in the middle)
If its his igniter thats going bad isn't there a way he could possibly swap his igniters firing order so that he can have the igniter on cylinder 1&2 fire cylinder 3&4, and vice versa, and then see if his problem switches over to cylinders 3&4?
