Intake Manifold Question
    I have my intake manifold broken down, I took everything apart. From my other engine, where the piston blew, I have pieces of metal up in there, and it ruined my fuel injector, so, I'm cleaning it up and putting new injectors in, to put on my new engine. What should I use to clean it up with, carbon cleaner, water? Thanks.
    Facebook.
    Xbox Live: Call Of Duty4: Unt0uchable15 --I'm a beast!
    Member Ride
    degreaser, carbaurator cleaner, wire brush ... thats what i used
      I appreciate the quick response. You used this inside the manifold, correct?
      Facebook.
      Member Ride
        If thats were you need to clean then yes use it inside the manifold
          Thanks, I just wanted to make sure I could use degreaser inside of the manifold, I didn't know if it would mess it up or w/e, so anyways, thanks for the responses.
          Facebook.
          Member Ride
            Well if you took it apart and its off of the head then it wont mess anything up.
              Alrighty, thanks for the help.
              Facebook.
              Member Ride
                oh one quick thing cover any sensors ... degreaser will cause them to go bad. If you want you can use a dremel with a wire bit on the inside of the manifold with some air to blow it out if you dont have a compressor just go get an air can duster ... GL with it
                  What should I cover the sensors up with?
                  Facebook.
                  Member Ride
                    Just remove the sensors. You have the IM off the car so taking the sensors off to clean is easier than trying to cover them.
                    MR Thread
                    GhostAccord 2.4L Blog
                    by Chappy, on Flickr
                      Yea, I already did that, I figured taking them off would be easier. Thanks.
                      Facebook.
                      Member Ride
