What's behind dash clock? Want to replace w/gauges
    So I took my clock out today to see what was behind it and i really couldn't tell other than the plastic behind there. What I want to do is remove the dash clock (since i never ever use it) and install some gauges in there. I have a single DIN 3 gauge holder similar to THIS and I want to cut out the slot for the clock and make it bigger and deeper. So my question is, is this possible? I have pics to put up so you can see what I'm thinking about but I can't find the "Manage Attachments" button as described in the FAQ, either way I think you get the just of my question? Thanks in advance.
    "Live While You Live & Just Be Happy"
    A 10mm bolt that holds the center of the dash to the cowl panel. Not much room for anything behind it...
    http://www.cb7tuner.com/vbb/showthre...=1#post1823428
    My Custom BB6 Dash Swap Thread
      You can go deeper but you should remove the dash its really tight to do anything since the windshield is there.
      I removed the clock in my first cb and put a vafc. Looked awesome back in 2005 lol!
      [Img]http://www.****.com/mauri/my%20car%20pics/vafc.JPG[/img]
        Ok I think that i can go deep enough with out cutting further back but it looks like you cut on the sides to widen the clock for your vafc. Is there anything that I should be concerned about on the sides before cutting?
          Does anyone know If I can make the slot wider without any issues?
