wiring diagram for vigor (cc2) headlights
    i bough a switch from UK-Accord and i dont fing the famous diagram for this switch..... plz help
    edit by uncle_el:
    he has cc2 (vigor) headlights on his cb7, and wants to be able to activate the integrated foglight at the push of a button. the button/switch he has and would like to use is the buton for the rear foglight (edm/jdm).
    My Ride Thread
    The fear of death follows from the fear of life. A man who lives fully is prepared to die at any time.
    Mark Twain
    FaceBook
    are you referring to the switch, to the rear fogs themselves, or both?
    as far as i know, there is no wiring diagram for the rear fogs. those in the u.s. (i see you're in canada) that have purchased and installed it just winged it
    options for installing rear fog light:
    1. install it without wiring it up.
    2. install it, and wire it to the tails. thus, it would come on when you hit your brakes.
    3. install it, and wire it through the car, and use the switch/button/your own button/toggle, thus it would come on when you pushed the button/flipped the switch/toggle.
      its the switch,, not the fog,
      i whant to use the famous switch to active my CC2 headlight yellow fog so in the switch i got 4 pin and 2 other
      -_____-
      like this...
      some one can help me :S
      My Ride Thread
      Mark Twain
      FaceBook
        -_____-
        like this...
        sounds like you need to a diagram for activating the fogs of the headlight, and not the rear fog.
        i'll change the thread title to reflect the actual question.
        btw, you should read this thread: http://www.cb7tuner.com/vbb/showthread.php?t=9336
          i restart my question (damn its difficult)
          i have buy a fog switch from Uk-Accord but only when i have send the cash i have read they are REAR fog switch and nobody know how plug them and i am fu**ed up ....
          i think i will cry a lil bit
          My Ride Thread
          Mark Twain
          FaceBook
            its not the end of the world..
            you can buy an aftermarket fog light wiring kit and use that to power up the H3 fogs on the CC2 lights. or you can buy my JDM CC2 fog switch for $1000
            and then you can do this:
            5.6L V8 32V DOHC
            JDM HERITAGE - US BUILT
              i have alredy a switch....... and i dont know how plug it
              thx alot !
              h3 fog ???? you mean i have high beam low beam and h3 fog ???
              My Ride Thread
              Mark Twain
              FaceBook
                it should be identical to hooking up a set of aftermarket or OEM foglights.
                the pink text explains what each pin of the switch is for, and youll notice E is the "turn-on" wire. that wire goes to a **30 amp** relay which turns on the foglights - the green text explains where each pin of the relay gets connected.
                [img]http://www.****.com/pics/hooking-up-fogs.jpg[/img]
                  holy god ! thx alot man !!!
                  but can i plug it directly ? why i need a relay ?
                  thx again
                  My Ride Thread
                  Mark Twain
                  FaceBook
                    thx again
                    a relay is needed in almost all cases when wiring up different things to a switch, unless you get a heavy duty switch that can handle the current.
                    the stock foglight button is a teeny switch which would burn up if you ran the foglights through it. so if you use the switch to flick on a small relay which requires very little current, the relay acts as the heavy duty switch and is the thing that connects the power from the fused battery connection to the foglight bulbs. this is why i say the relay must be a 30amp relay.
                    i provided the diagram for hte foglight button, when you buy the relay it should come with the pins labelled or at least have a diagram on the back of the box matching the numbers i listed in the picture.
                    if you can find one, you can also use a pre-made foglight wiring harness instead of doing all of this wiring yourself - its a premade harness where you hook one end to the battery, the other end to the foglights, and theres a skinny white wire which you would hook up to pin E on the button. ive seen the harness for sale in walmart and autozone.
                      ..h3 fog ???? you mean i have high beam low beam and h3 fog ???
                      you're telling me that you didn't notice the 3 separate bulb housings in the headlights??
                      you've got H4, H1, and the yellow built-in H3 fogs.
                      post up pics of the finished product when you get a chance.
                      5.6L V8 32V DOHC
                        yup i will post
                        and i dint notice the h3 because i dint open the headligh from now i i thinked it was a simple yellow like 1148 one
                        a very great thx !!!!!!!!!!!!!!!! to all
                        My Ride Thread
                        Mark Twain
                        FaceBook
                          i came from walmart and i dint found the famous pre made wiring.....
                          My Ride Thread
                          Mark Twain
                          FaceBook
                            fog light
                            yo cp. i got me a 5th gen accord . i needed to wire a rear fog light to it and you got it sorted with jus tha diagram i was just looking for
                            '' we racing or you just blowing smoke ?''
                              glad it helped you out!
