I just relocated my battery to my trunk. Followed the diy on the forum, but I have no power.
I used 4 gauge for the power and grounds, even the under hood fuse wire. I ran a wire from the under hood fuse panel to the starter, then ran a wire from the starter to the trunk into a fuse block, from that fuse block to the battery. Then for the ground I ran a wire from the battery to the bolt/nut behind the passenger side tail light. I had the positive wire hooked to the battery, then hooked the ground to the battery, when I did that, there was a lot of spark and it felt like the ground wire was warm. But I got everything hooked up, all tight and have no juice.
What could be the issue? I have no blown fuses, all the connections seem to be nice and tight.
