Valve springs for valve float.
    Hey, I was just wondering what valve springs are out for a F22B DOHC that would stop valve float reliably. I've seen dual springs for 75 psi of holding force, but I don't know enough to determine if this is adequate.
    Been a long time. Still alive...
    you're going to have to give an RPM range if you really want an answer.
      Ok, I know I've seen ratings on springs like "UP TO 10,000 RPM!" But I'm not going to run that...
      Probably like 8K.
        I know the bisimoto springs are good for at least 7500, prpbably more
        1990 accord Honda-Challenge, H22 powered
        newer race video,older race videos
        1991 accord parked, parts and back up shell
        1993 accord acquired 6-11-16
          75lbs should be fine...stock is like 45-55.
            Neat, I'll probably pick up a set in the near future. Thanks!
              Would stiffer valve springs have any adverse affects at lower rpm's?
              H22 Fund Cancelled. Flight training underway.
                a valve spring will help with wilder camshafts but at low rpms no.
                  Don't forget that the higher seat pressure springs that you use. The faster your valve seats will wear if not machined properly. Make sure you get a valve job done that is specific to your spring pressure and style of driving you intend to put them through. Race/Street Strip/Daily Driver.
                  MR Thread
                  GhostAccord 2.4L Blog
                  by Chappy, on Flickr
