the title says it all. how can i disable my vtec on a h22
how to disable vtec?
the vtec was made for economy of gaz.when your in the vtec , bellow 5200 rpm,the vtec system maintain one intake valve to open fully.when vtec disengage ,5200rpm+, the intake valve open fully and them you have more power.vtec works with oil pressure and a celenoid so you have to control those 2.for the oil pressure its easy because your already have your max pressure ( or pressure to disangage vtec ) at about 1500rpm and for the celenoid you have to control it with a switch on/off conected directly to a 12v source if the celenoid works on 12v. if not you have to find another alternative.i will test tomorow at what voltage the vtec disangage.
so now you see why a want to disable vtec?
Originally posted by SpitFire View Postand of you disconect the celenoid it will maintain one intake from opening fully.
Damn F22B SOHC's
I don't believe the vtec system in the h22 uses one pertially open valve in non-vtec, that would be an econo vtec, like the d16z6 or y8
h22 should use a system that uses all valves all time but opens them further while in vtec
all vtec system are the same . the h22 is like a d16y8 or z6, one or mayby 2 of the intake valve is not open fully when vtec is engage under 5200rpm.they do not open further but fully when vtec is disangage.so if you can have the valves fully open at all time you make more power.the i-vtec system allow your valves to open gradualy to fully open from mayby 1000rpm to +8000 rpm .Last edited by SpitFire; 10-25-2008, 01:48 AM.
um, from my understanding of it, the type of vtec that is in the h22 (2 different cam profiles on both the intake and exhaust sides) vtec is ENgaged above 5200 rpm. disconnecting it would keep you on the less agressive cam profile all the time. if you just want fuel economy, good idea. otherwise, nice try.
Originally posted by Stephen Fry'It's now very common to hear people say, "I'm rather offended by that", as if that gives them certain rights. It's no more than a whine. It has no meaning, it has no purpose, it has no reason to be respected as a phrase. "I'm offended by that." Well, so fucking what?' —Stephen Fry
i dont want to disconect it and be on the less agressive lobe. i want to be on the more agressive lobe all the time.if you just disconect it you just have economy all the time.by sending in a voltage (dont know the voltage yet) it disangaging the vtec all the time and the valve open fully all the time.
Originally posted by SpitFire View Posti dont want to disconect it and be on the less agressive lobe. i want to be on the more agressive lobe all the time.if you just disconect it you just have economy all the time.by sending in a voltage (dont know the voltage yet) it disangaging the vtec all the time and the valve open fully all the time.
Originally posted by Flatline View Postor you could just tune VTEC to kick in at 1k or something....but thats a little retarted to me
i believe there would be a problem with not having enough oil pressure to do the switchover at lower revs. its not just the solenoid keeping it open, its a flow of oil that acts like a hydraulic ram. IMO, youd be better off getting a cam that eliminates vtec altogether than to risk the additional wear on the engine that a lack of oil pressure would cause.
edit: i just did some research and the h22 uses all 4 valves per cylinder at all times. vtec-E is a different system that only opens one valve on each side a small amount until the crossover point is reached.Last edited by steelbluesleepR; 10-25-2008, 02:13 AM.
