Skunk2 intake mani?
    any ideas of why its idling so high?? Is it because of the butterflies being taken out? This sucks. after it was warmed up it didnt stay at 3000 anymore. it jumped from about 900 to 2600 rpms.
    My New Ride
    http://www.cb7tuner.com/vbb/showthread.php?t=82630
      I was going to say throw in the plentum spacer and take out the butterflies. Seal up the holes and throw on an H23 Plentnum.... Instant difference on the throttle response and feels like it has a little more torque.
      CB7Tuner Resident Gamer!
      PSN: JDMcb7TX
        The plenum spacer is on. I took the butterflies out. That was it though. Just the butterflies. Everything in the spacer stayed. I can pick up and h23 upper plenum from my old job at the junkyard. Is there any other way to fix this? My check engine lights on now too
        My New Ride
          It is going to be a routing issue with the Vacume lines I think....
          PSN: JDMcb7TX
            Think I should switch them up? After I get back to town ille go get my haynes manual and make sure all hoses are hooked up correct
            My New Ride
              Have you tried cleaning and adjusting the iacv and fitv? Check all your vacuum lines as well.
              http://www.cb7tuner.com/vbb/showthre...ight=iacv+fitv
                You will have to look at a manuel for the H23 Plenum not the stock one.... Compare both manuals. Just to double check that all lines are being ran to the right place.
                PSN: JDMcb7TX
                  Originally posted by turbo90accord View Post
                  I think we need to keep the flaming of peoples income out of all forums. you do what you can with what you can thats it. this comment is a bit over the top and unessassary by all means.
                  I wasn't flaming anyone's income with that. i was making it a point that not everyone has money to blow. He doesn't think that $190 is a lot to spend on the car part in question. I do. The reason is because he apparently makes a little more than double what i do a year. I made 11k last year and 12k the year before. And it doesn't look better in the near future.
                  But i see no way i could flame someone's income when mine is a fraction of theirs. Was it the F-bomb? because i have a habit of dropping those all the time.
                    Thanks guys. I plan on cleaning everything up tomorow. Go grab some carb and choke cleaner. I hope it works. I can't stand not driving my cb. And there's a guy that wanted to try racing me tomorow. The idle shouldn't make me throw a code though correct? The light just came on after about two mins of driving. Haven't pulled the code yet though.
                    My New Ride
