If you look at some chamber designs they are only a tub shape and don't even cover the diameter of the piston. All depends on the quench areas and how much clearance you have between the piston and cylinder head.
This build being a boosted one I would assume that the pistons are dished/stock. Therefore there is no real danger of piston to head or valve clearance issues. The piston to deck height is -0.002 (out of the hole) stock. so I don't see this as even being an issue really.
IMO if you were to go the other way around it would be more of an issue. The mushroom head = 85mm bore with an 87mm cylinder head chamber. For example the H22 head on F22 block swap. This actually puts a dead spot in the chamber for carbon to build up in. In turn this could cause hot spots. Not a real issue when you go 86mm bore 85mm chamber.
Just my 2¢ worth!
Good luck ether way!
Just my 2¢ worth!
