I was thinking about getting a delta 272 cam regrind, valve springs and retainers. You think it is wise to make a high reving f22 motor? Springs were tested to 9000 RPMs. i figure the cam regrind will still be able to make power at that high RPMs.
Also what are valve locks for? anyway the bottom is the links for where i was thinking about purchasing all this? so would this be a good idea or bad? if it helps my motor has 125k miles on it. daily maintainence done as usual. car is 5 spd.
http://www.f22parts.com/item_Singlevalvesprings.htm
http://www.f22parts.com/item_Retainers.htm
