There's a sticky in performance that should help you out with thyose specs.
f22 crank in h22?
There is NO USDM F22BOriginally posted by owequititThe JDM F22b has a compression ratio of 9.3:1
The USDM F22B is still 8.8:1
They did this to make sure that all of the USDM cars would run on cheapo 87 octane without needing fancy electronics. And they met thier power targets with the low compression, so...
You're so particular about being complete with all the information you post, that it's ironic you wouldn't care about getting something so simple correct such as engine codes. It pisses me off when people fuck that up. The F22B is what it is and should not be used to describe anything else; when people do so it confuses others that don't know and perpetuates the stupidity. Add that little X there and it changes things completely.Originally posted by owequititOh gee. F22BX.
Happy?
Originally posted by DoctorCipherYou're so particular about being complete with all the information you post, that it's ironic you wouldn't care about getting something so simple correct such as engine codes. It pisses me off when people fuck that up. The F22B is what it is and should not be used to describe anything else; when people do so it confuses others that don't know and perpetuates the stupidity. Add that little X there and it changes things completely.
So are you happy? I irritates me as well, but I am still human.
what about this in an h22 block?Originally posted by gloryaccordy View PostF22 crank+H22 rods+H22 pistons= KAPIYAHHHH goodbye everything between the crank and the valvesprings...
F22 crank+ H22 rods + F22 pistons=
F22 crank + F22 rods + H22 pistons
longer stroke than h22 crank, shorter rods than h22, Higher compression pistons than f22.. i believe this would work or will the pistons hit the head? Also would the compression be higher than the Stock h22 or less? I have a hard time figuring this shit out
I read the links below earlier today, these guys did the math already. Keeping the H22 pistons and increasing stroke also increases compression.
Apparently, using even a stock F23 crank and rods (with modified h22 or S2000 pistons) leads to some insane n/a power levels....like 300 whp! wtf?
http://www.preludeonline.com/f93/h23...uestion-98611/
http://www.preludeonline.com/f93/h23...04/index3.html
http://www.honda-tech.com/zerothread?id=1232811 -H/F bottom end measurements/comparisonsLast edited by lucid; 08-04-2008, 01:44 AM.
PM me and get it done right!
