Top Speed Question.
    Top Speed Question.
    Now i didn't exactly know where to post this, nor was I able to search for the right thread i was looking for.
    But my question is this:
    When boosted or NA to more than 250 hp..how would the Top speed be effected? I mean does top speed go higher if Hp/Tq goes higher?
    *Needs*
    -New shocks
    -Struts
    -Drop
    -Cleaning
    -New Tires/Wheels
    -New Window Tint
    -Alot more lovin'
    topspeed= gears=tranny
    the higher the HP and TQ numbers are the faster u'll get to the speed the tranny is built for
    lets say an H tranny's top speed is 165mphs (SUPPOSING)
    regular power u'll get to that speed in 1 min
    with 250hp or 300 u'll PROBABLY get there in 30 secs
    like i said this is if it were real, top speed wont be affected but the time that it will take u to get there will decrease
    Just do what PR CB7 said.
      Don't forget wind resistant and drag and lift. On a dyno you can sure get to top speed where your gear+tranny combo make. example ..165mph
      In track/street driving even if you have 100 Miles of empty straight road, you will never go faster then 140mph due to wind resistant and drag and lift. you either need more hp/tq or better aeronamic for the car to overcome and get close to your gear+tranny true top speed. just a while guessing you will need close to extra 15hp/11tq to go 1mph faster.
      90 Accord Coupe LX, Stock JDM H22A Engine 10.6:1 - Stock Automatic LSD MPA1 Trans, JDM P13 Auto ECU + JDM P19 TCU. Tune with Greddy E-Manage Ultimate
      < 317WHP/227WTQ@11psi> B/W S256 turbo, Daily Driving on 93 pump gas - since 2006. Driving Turbocharged CB7 Accord since 2002.
        Yep. Givin the exact same car and transmission, adding more power will not make your top speed higher UNLESS with your old (lower power) motor, your top speed was limited by drag (aerodynamic mostly).
        If you're in top gear and you're bouncing off the rev limiter, you are not drag limited at that point. You are gear limited.
        1990 Accord LX Sedan, B-49M
          if you have a turbo you aren't running stock ecu...no speed limiter...rev limiter yes...but red line is altered with such mods...higher yes? top speed thus goes up. eh theory theory sorry
          But...all theory aside...what is the top speed achieved on a dyno on a properly tuned turbo cb7 with stock (h or m series) tranny?
          ____
            ok so i guess the only top speed rise is from the F22 to the H22/23 swap then?
            *Needs*
            -New shocks
            -Struts
            -Drop
            -Cleaning
            -New Tires/Wheels
            -New Window Tint
            -Alot more lovin'
              what is the fastest speed that the f22 setup has ever ran with stock tranny ratios?
              Originally posted by zack_odom
              Yummmmm. I'm going to go eat some Buddy Club sauce with my Mugen Spoon.
                Check it out.
                Tire width: 195
                Aspect Ratio: 60
                Rim Diameter: 15
                Transmission Gear Ratio: 0.705 (Fifth)
                Differential Ratio: 4.062
                Lands you right about 150mph @ 6000rpm.
                Not 100% accurate obviously.
                Originally posted by TurboZach
                Accords are for winners. And Grandmothers. But mostly winners.
                  So according to the gear-speed calculator you could hit 202 mph at 8000rpm on an F22 tranny if you get rid of rev limit. I wonder how much power you would need to do that on a highway lol
                    Most people have covered it in here. You are limited by your gearing in your trans. There are ways to maximize it. The stock gearing in the cb is capable of a really nice top speed. These things matter (most are already covered):
                    1. Gearing in trans/FD
                    2. Revs
                    3. Tire size is really important as it can increase your speed or decrease it. Might wanna keep that in mind.
                    4. Wind Resistance/Friction/Drag
                    5. Nawzzzz
                    6. Make sure you choose the right tire rating
                    7. Go to Nardo
                      Depends on alot of things:
                      My setup:
                      215/40/17 Tyres
                      Rev limiter - 6510 rpm
                      F22A engine 16G turbo
                      F20A Gearbox
                      Max speed on the limiter - 210 km/h
                      My old car the same but no turbo and no rev limiter (same gearbox):
                      Max 180km/h - Wind resistance is the limiting factor
                      Most noticable difference is the amount of time getting up to speed
                      My 5.7 LS1 Holden Ute
                        I dont see the point.
                        Unless you plan on drag-racing it, where will you ever have the road or ability to get an accord up to 130+ and maintain speed? And why would you wanna do it?
                        Or am i missing the whole point?
                        Fastest ive gone and maintained is around 95. Fastest ive ever gone, with 200k+ miles and an AT, is around 111(+/-). And i wasnt topped out, i was simply too afraid to go any faster.
                        I mean, to answer your question, which i think a few ppl have done already, youre top speed will not go up. With more HP, you will simply get there faster.
                        Originally posted by Jarrett
                          Sounds about right, altho I've never taken mine past 4th gear. With my setup (H22A4 w/ stock Accord tranny, Spoon ECU, and other mods), 3rd gear at 7400-ish RPM (stock tach not accurate), I already hit 180km/h (110mph?)..Shift up to 4th, I'm JUST at VTEC crossover @ 4800RPM..Before I can redline my 4th, my speedo needle is already buried way past 240km/h (150mph), soo I'm guessing if I do redline 4th (or more like ever having enough room to redline my 4th), I'd prolly be sitting at 160-165mph, if not higher...And 5th is like 4th all over again haha so 200mph is definitely reachable.
                          I HATE long gears tho Yeah you get top speed, but what's the point? Like I said, I can't even redline 4th, 'coz none of the local highways are long enough to let me do so But given the space tho, I'm sure I can reach that no problem. 4th gear in VTEC still pulls pretty hard, 5th gear also pulls once I get past 4000RPM Whether my car will survive going 200+mph or not, that I will never know
                          Ronald
                          |~~~~~~~~~~~~- Project CL1 Euro-R continues -~~~~~~~~~~~~~~|
                            Good point
                            As my above post states I have been 210km/h yet that was for at most 3-5 seconds then back down to 100km/h. And that was for tuning reasons
                            In reality there is no need to go above the legal speed limit, Unless you are on the race track.
                            Its not like you save alot of time (even on a long journey) going above the speed limit, taking the risk that you endangering the life of yourself, as well as other people that you don't even know . . .
                              It is cool to think about it.. but let's be smart and never attempt to redline 5th in our accords lol
