Auto F22a1 looking for ECU upgrade
    I hear you can i can use the P12 ECU, which is off the f22a1 prelude. but what else can i do?
    chips?
    other ECU?
    is a PT6 even an upgrade for my car?
    Be Clean
    Chipped is only worthwhile if you've added some serious mods, the pt6 is only worthwhile if you have the f22a6 IM.
    For an f22a1 with no mods or with IHE, the p12 is going to give you the most improvement.
      i do have the f22a6 runners and H series plenum, however i don't have the vacuum sensor to operate the butterfly valves. what i did with the butterfly valve vacuum was stick it somewhere in the plenum.
      so can i use the PT6 or compared to the P12 is still the best?
      Be Clean
        the butterflys wouldnt work with the p12 would it or is that a stupid question
        UNDERGROUND SOCIETY
        NEW COUPE MEMBERS RIDE THREAD COMMING SOON
          P12 doesn't have IAB function, so NO. because the P12 is off the F22a1 in the prelude, and the ECU makes 10 more horses. The F22a1 has no IAB and no butterfly valves. -- good question.
          I AM WONDERING THOUGH IS CAN A MANUAL P12 WORK FOR MY AUTOMATIC?
          Be Clean
            yeah. all the ecu controls is the engine
            UNDERGROUND SOCIETY
              Go for the PT6, find the vacuum box and hook up the IABs. Plus better maps, no Speedo limit and you can always do the A6 cam swap and take full advantage of the PT6.
                couldnt you just remove the butterflys all together an run the p12 anways
                UNDERGROUND SOCIETY
                  sweet. manual P12 work for my auto tranny.
                  Be Clean
                    i've seen in all motor builds, people like to take off the butterfly valves for more power. and i'm probably going to get my camshaft a stage 1 regrind.
                    Be Clean
                      Them I'd say skip both aforementioned ECUs and get a chipped unit like a P06. Run uber or chome on it.
                        what's so sweet about the P06?
                        Be Clean
                          It's not the P06 that is sweet, it's the things you can do with it.
                          I have ran my stock motor with it, my F22B1 and now my H. You have the ability tune change the fuel and ignition maps and get a true "tune".
                          I run Uberdata or Crome. Depending on who does the tuning.
                            po6 is out of a civic correct ?
                            UNDERGROUND SOCIETY
                              I run Uberdata or Chrome. Depending on who does the tuning.
                              that's wild. doesn't ecu tuning cost some serious dough? i'm noob sorry.
                              do you mean google chrome?
                              Be Clean
