ebc or mbc
    ebc or mbc
    Just wondering what the advantages are of having a manual boost controller over an electronic boost controller besides the fact that it's cheaper? I plan upping my boost in the future and I would like to have different levels of boost available during a run at the track and I know that there are dual stage mbc that can be adjusted during a run from inside the cabin, but would an electronic boost controller be more suitable for want I want? For example at the track I would like to launch at a lower psi and then be able to raise the boost level during the run, let's say from 8psi to 18psi. There is a good mbc for $115 that has dual stage and then there are the expensive ebc like Greddy and HKS that are much more, but I'm wondering if it's better to pay more and have an ebc?
    SOLD!!
    Boosted H22
    375whp 298 ft/lbs at 15psi
    check out xenocrons EBC
      I'm looking into a mbc called JS Boost Controller
      SOLD!!
      Boosted H22
        MBC's can spike easily and adjustment is a guess each time you turn the knob.
        A dual stage MBC (semi electronic) is good If you want to flick between 2 different settings.
        EBC's are more accurate, and do a better job of controlling boost pressures.
        My 5.7 LS1 Holden Ute
          As said ebc is the best way to go. No poping the hood to guess as uping the boost.
          99 GS300 (Aristo) 2JZ Power
          Bought from:gdout, bb6-sh
            Hold on, how do these work (sorry for the newbish question). Wouldn't this have to piggy back onto the ecu to modify the tune as the boost raises. I'm just a little confused here.
            "The Turtle"
            DD/Trail Rig/Mud Bug
              Boost by gear son. eCtune has it. All you need is a boost solenoid.
                This is what I wanted to hear!
                SOLD!!
                Boosted H22
                  Either by using a modified ecu, or the controller that comes with EBC's.
                  If your using an ecu to control it you only need the solenoid. If your don't have a modified ecu you need an electronic controller.
                  Boost by gear is really only useful for traction issues.
                  Theres obviously no point running like 20psi in 1st gear.
                  I keep meaning to setup boost by gear for 1st and 2nd gears on hondata, just never get around to it and I end up just using the throttle to control it
                    Only? You make it sound like traction isn't a big issue.
                    Boost by gear is better than an EBC, imo. Just have 3rd and 4th be your max psi.
                    OR, use a semi ebc and have it on a toggle switch so you can switch it to super high boost whenever you want to. AKA, the noggle switch.
                      I diddn't mean to sound like that, but technically that IS its only purpose
