H22 injector...
    H22 injector...
    under 10 psi sub 300hp build.. What injectors can I run.. I am trying to find something I can get off another stock car that just "bolts" in... Factory resister box,etc... Can I use dsm? If so from what year and model?.
    I think I read DSM blue tops (no clue on the years/ models) will work just fine. The only thing is the ports on the rail need drilled out a little to make em bigger.
      If your going to look for DSM injectors. Look for the 95+ Black top 450cc injectors. They have the updated "v" spray pattern. They are found in the 95+ Turbo Eclipse, Laser & Talon.
      The ports do not need to be drilled out. It's only the lower bushings/seals that need to be made larger. It takes all of 5 minutes with a dremel/drill and an 80 grit sanding cartridge roll.
      MR Thread
      GhostAccord 2.4L Blog
      by Chappy, on Flickr
        I see... Thanks!
          STOP.....NEGATIVE INFORMATION!!!
          nothing needs to be drilled!
          what you need to do is take your pinky and lube it up with oil
          then spread oil on the rail seal.
          do this for each injector port.
          with the injectors installed on the fuel rail, take your pinky and lube the injector on the outside where it goes into the port.
          push fuel rail on and tighten 10mm bolts.
          you do not need to port these bushings or ports. if done incorrectly can only lead to issues down the road!
          as far as OPS original question. DSM injectors are good for the money you should find a set of blue tops and they are plug n play.
          Well with the exception of being tuned. As long as you have the OBD1 resistor box still connected. which is the rib looking box connected to the driver side engine bay, by the shock tower.
          I assume this is for a boost project and you are not just trying to add dsm injectors to your stock engine without tuning.
          MadLab Racing
          Southern Maryland
            I did not drill my seals for the DSM injectors either. But it was a TIGHT fit, no problems though.
            The H22 injectors would probably only be good for UNDER 5 psi on a small turbo... basically useless for a turbo build
              Stop! Solid information that will save you from vacuum leaks and possible fuel leaks in the future!
              So how long have you had them installed? What happens to your squished seals over time? I know what happens, they will split and cause a vacuum leak if you don't ream them. But no need to take my word for it. If you want to do it this way and force them into the seals go ahead.
              Do not force your injectors into the rubber bushings.
              Why would you suggest to the op to buy the older less efficient blue tops? The black tops are newer and have a much more effective spray pattern.
              MR Thread
                actually it is just a more condensed rubber, I ran them on my setup for over a year, no issues..
                so whoever told you to dremel and you believed not exactly sure why.
                please get some facts straight first. I do not deliver false information.
                this will not cause vacuum leaks and I never said get the black top over the blue top. but then again the blue top is known to what works.
                almost everyone on this forum have set them up this way WITHOUT dremel. so what you think vs. experience owns!
                when you do this, do not forget to slowly tighten the fuel rail. one side at a time. like torquing bolts. this will help create an even pressure amongst all seals.
                MadLab Racing
                Southern Maryland
                  I've honed quite a few sets with no problems ether. there is a set I did 3 years ago still running strong with no issues. So don't say experience owns. It seems as though there are two ways to do it. However I was always taught not to use excessive force to push a metal object into rubber o-rings. That was just my experience as a mechanic though, why should that count.
                  You are correct, you didn't say black top over blue, you said to use the old crappy blue tops over the newer & better black tops. reading owns!
                  MR Thread
                    honestly, they are dsm injectors, they work for a budget build!
                    I am not going to argue over a measley 250 hp build.
                    dsm injectors are budget build. so it really does not matter which ones you get.
                    and sure reading owns. and yes dremeling if properly done can be a descent way to go. but honestly most people that are asking these questions. no offense to OP, are rookies in this situation. so they have a higher chance of messing the seals up than a mechanic. make sense?
                    MadLab Racing
                    Southern Maryland
                      MR Thread
                        i'm with him.
                        i dremelled/bored my first set of DSM rubber seals, and they leaked fuel.
                        bought 4 new ones from honda, REMOVED the plastic seal under the rubber ones, lubed up the injectors and GENTLY used pressure to push them in, and haven't leaked since
                        so yes, people have had success with both ways
                        BB2F22-T3super60:250hp/275lb-ft @10psi
                          i'm with him.
                          So why did you side with Drummersteve7 and quote that the information that was posted is negative information? Then in the next sentence you do an about face and say both ways work
                          As for them leaking after you honed them. My guess would be that you took them out a bit too far. I've never had a set leak yet... (knocks on wood!)
                          MR Thread
                            weerrrd. every body breathe haha.
                            Im going to be using the DSM blacktop injectors for my build.
                            I had read about the spray pattern. And also about how the blue tops can sieze up or something, leaning out and detonating my engine. I wasnt to thrilled about that.
                              they are dsm injectors running on a honda. black or blue, both can have issues. DSM is the budget build like I have said before. and several people have ran them with no issues.
                              MadLab Racing
                              Southern Maryland
