innovate lc-1 12 v constant or ignition
    i thought u said that 3.84 is what i would get hooking it up like i got it, not sure what to do, cause i added fuel to a different chip last night, kinda through the whole range and got it way to rich, just trying different things right now to learn, trial and error, anyway i was reading a 8.9 afr at idle but somehow wot went to 18, way lean. The thing is that after i put that chip in that was running rich at idle, crome showed the 02 voltage at .15 and cannot figure out how it dropped like that.
    So are u saying the way i have it wired up, the brown anolog 2 wire going to d14, i should be seeing 5 volts or not, sorry just trying to understand and figure it out. when i get back home im going to check and make sure ive got it on d14 but pretty sure i do or it wouldnt be reading anything. but i should be getting 5 volts the way i have it? thanks for your help and your patients..... Josh
      The highest voltage that you will see through D14 is 3.84v. the LC-1 will still send out up to 5v you just won't see it.
      PM Sent!
      MR Thread
      GhostAccord 2.4L Blog
      by Chappy, on Flickr
        I think im going to go ahead and get an afr gauge, perferably an innovate to match my wideband setup, getting tired of hooking of my dattalog stuff and laptop just to try to see what my afr is. would u all suggest the innovate brand or just any, want it to hook up to the lc1 and didnt know if the others hooked up the same, thanks.....
          I have the Innovate LC-1 hooked up on my turbo accord, I ordered mine with the XD-16 optional display gauge when I bought it. Well worth the $ It connects to the LC-1 via the serial cables so it is very easy to use. The gauge itself I believe also has its own datalogging to your laptop, I have only used it a few times for that purpose though. Also a neat touch, each individual LED gauge sweep segment is infinitly adjustable for color - So once you have your AFR's down you can adjust the colors to your own preference for what you feel is safe. For instance on my gauge if have a "normal" AFR set to green, rich is blue, red is lean, and I have some mix colors in between.
          The gauge is made of a very good quality in my opinion, I have never had any issues with it, and Ive been using it daily for about 2 years.
          I cant remember if the XD-16 gauge is actually manufactured by Innovate Motorsports or not, I suppose a quick Google search would back that up.
          That would be your best gauge in my opinion to pair with the LC-1
          Edit: Also Innovate sells a line of gauges called their "DB" line, basically an LED display gauge, standard blackout when off. Looks nice, just not as many bells and whistles as the XD-16 has. They also have a G2-G5 gauges available - basically an analog needle version, although it is technically still a digital gauge since the needle is driven by a precision stepper motor.
          Edit (again, geeze lol) Apparantly the XD-16 had been discontinued, to be replaced by the MTX-L line. It looks very similar to the XD-16 though, except I dont see the small push button and the light sensor thats on the XD-16 face.
          ON_N20
          Nitrous = Been there. Turbo = Now. Nitrous + Turbo?... LOADING
