turbo kit for our cars
    I was looking at the turbonetics for the 9497 accords and it says you can only boost to 250hp
    I'm wanting 300 min
    can I get the kit and change out the parts to boost to more whp?
    if not, what kit do you recommend?
    visit vgruk
    Do you have an f22b head? Also you should look into arias pistons.
    Exhaust port configuration between f22a and f22b is different.
    Also that $3900 kit is missing items.
    "Complete turbo kits normally include the manifold, turbocharger, intake, down pipe, fuel management unit and all lines and hoses needed. You need to purchase intercoolers, piping, blow-off valves separately in most cases, unless otherwise noted in our product descriptions."
    If it were me I would secure a reliable dd then I would upgrade pistons to aftermarket forged and tear down the block to check its health and install ks bs eliminator. Then piece a T3/T4 turbo kit together yourself to save money and get the right parts. Consider methanol injection. When all assembled and idling bring it to a dyno for a healthy tune.
      ooh yea i got all that covered. i am just putting a list together for a year or 2 down the road. im at the point where i need to start getting an idea of what turbo i need to run. thanks for the help. i thought getting a kit would be cheaper.
      visit vgruk
        Where is the link to this so called "kit" you are looking at?
        '94 JDM H22A: 178whp 146wtq
          http://www.andysautosport.com/honda/...s/turbonetics/
          Heads up, a better kit for F22B heads can be found on eBay with the Turbonetics T3/T4 turbo included:
          http://www.ebay.com/sch/i.html?_odkw...+f22a&_sacat=0
          It is much cheaper to source the items individually than order a kit that you will still need to source motor specific parts for.
            That's probably not the best "kit" to buy IMHO. For that money you could do better custom, or by Treadstone, which I believe is rated to 400-500whp with proper components.
              When you buy a kit, you're paying extra for the convenience of having all the necessary parts assembled for you. The parts found in a kit aren't always going to be the best for your purpose. You'd be much better off assembling your turbo setup yourself. Not only will you be sure to get the proper parts for your needs, but you'll also be sure to learn what each and every part does, and why. When boosting a car that wasn't designed to be boosted, it's VERY wise to know each component intimately.
