damn. 2 days and already something is majorly wrong. Here's the riddle, never ran the car past 4K, never saw more then 4 psi, engine bay is oven hot, running two step colder plugs gapped .28-.29, running chipped ecu on rich and really retarded timing. After running it for about 15 min, I stop and begin to pull into a parking lot, halfway into the turn car stalls(may have been my fault, not sure). Now car wont start. Who knows what's wrong? My guess was flooded engine or fouled plugs. My dads is timing belt jumped. Car won't turn over.
Turbo Progress
that sucks dude, when you say it won't turn over, do you mean the engine won't rotote when you try to start it? or just turns over and over. i dout that it is flooded scince it is fuel injected. to see if the timming belt is gone, take off the dizzy cap and try to start it, if the rotor doesn't spin the belt is broken. later.
Originally posted by 92exyeah, the first slightly tuned map made for the f22b. I remember you saying you added 5% fuel and retarded timing a good bit, so it should be safe until I get my wbo2 on tonight. Plus I don't go past 3K.
Just switched to ngk 2 step colder plugs, 7f I think, gapped .28-.29.I hate thieves!
your map should run fine. I ran it for about a month when I wasn't turbo'd. I planned on running it yesterday night and this morning and putting a wideband in tonight. Plan worked, except I didn't even get to make it to the wideband part.
I pulled the plugs and the tips are white, so running lean... And my other guess is timing belt because it turns over and over. All help greatly appreciated.Shift_BOOST
BOOM!
Originally posted by 92exyour map should run fine. I ran it for about a month when I wasn't turbo'd. I planned on running it yesterday night and this morning and putting a wideband in tonight. Plan worked, except I didn't even get to make it to the wideband part.
I pulled the plugs and the tips are white, so running lean... And my other guess is timing belt because it turns over and over. All help greatly appreciated.I hate thieves!
you got problems because you tried to turn the engine over with a possible broken timing belt. Check compression...coulda bent some valves. I hope its something else tho.Knowledge is power...in EVERY sense of the word
Yeah could be timing belt, doesnt mean he wrecked anything! I jumped my timing belt on my talon and had it snap before and it never wrecked anything! Once the center of the T-belt was wore right out due to a little pin rubbing the belt, another time was because some dumb guy put a long bolt in a short bolt hole of the t-belt cover and that wore the side!--- My cb7 f22a1(s) lost compression, and so when the oil was warm it would die and wouldnt start until it cooled down!! So I bought a 85 escort! LOL! Ive got an f22a4 now! Will rebuild turbo before put it on!
WaC!
verdict in- it's the distributor. not fixed yet though, they kept ordering the wrong distributor. Tomorrow morning I'm gonna tell the to order a h23 and a f22a1 distributor. one of those should work. And the timing belt thing, my dad works on v8s, so of course it's not the same as a i4, but when I timing belt snaps, usually it backfires a bit.Shift_BOOST
BOOM!
