how many c b 7 guys are running it? what parts did you use?
water injection
yeah the really nice kits with progressive contollers and such run that much.. i am about to do this on my eclipse and i have sourced all the parts and it should run about $120, maybe less since i heard a rumor that a dsm fuel pump is made with all ss internals meaning it could be used as a pump for water, alky, or methonal (which would cut the cost in half since the pump is the most expensive part). it will be activated with a pressure switch meaning once i hit 7 psi (its adjustable from 4-20psi since you guys run less boost than my 18psi) the injection turns on. i am going to use smurf piss (49 water 49 meth 2 water).. anyone interested in a diy?Originally posted by 91accordexr33im looking to run this on my next setup since i dont wanna upgrade my FMIC...I've seen good kits for about 3-400...
if you could use a dsm pump, than you could do an ENTIRE 2 stage kit for under $120.. aquamist charges $500+ for that.. well the diy is going to have to wait because for the next 3 weeks i am going to be in laurel training..Last edited by flacopower; 08-08-2006, 01:45 AM.
this is what my DSM kit is going to consist of and basic prices:
going to tap into stock windshield resovoir (free)
either dsm fuel pump ~$15/ or shurflo 60psi pump $60
high pressure fuel injection hose ~ $15
12v solenoid to keep water from running through lines unless pump on ~ $25
hobbs pressure switch- $25 from napa
2 nozzles for injection ~$8
fittings ~10
clamps, jb weld, & tap- free
relay- $5
led's ~ $5
so around $110 for an adjustable stage 2 setup!
