Been having a few problems lately, namely oil being sucked through the turbo at idle causing excessive smoke out exhaust.
So I disconnected the SU carb, and charge pipes and refitted the original honda carb. It felt really gutless with standard carb.
Drove it into work today, and carried out a compression check, Results as follows: (should be around 175 psi)
#1 - 90 psi
#2 - 125 psi
#3 - 130 psi
#4 - 70 psi
So as you can see . . . bye bye engine, sorry guys I really wouldve liked to have had it fully up and running, so you could see some results.
Have just brought a 1992 Accord EXi. Still waiting to go pick it up. Not sure wether I will boost it or not, probably wait a while and get one with a bit less kms, The one I've brought has 240,000kms on it, so I would say its a bit tired for boost.
#1 - 90 psi
#2 - 125 psi
#3 - 130 psi
#4 - 70 psi
There will be one eventually...
