So i have a few intakes sitting around collecting dust. I was wondering since I am boosting my f22, could it be benificial to hack up a few intakes bore them out tig them back together and get some gains. I am just not sure how tog go about getting a good design. Not looking o make money. Not spending money. just a leisurley project.
Since i am boosting would it still matter how long the runners are?
Idea 1: make the runners bend so that the top of the runners sit lower than stock so i can triple stack.
Idea 2: gutt the upper plenum H23 of its runner dividers. Entirely gutt one spacer, second spacer would have butterflies removed and be bored out to look like the runner dividers that where cut out of the upper plenum.
Idea 3: cut the runners into 2 inch sections. bore them out tig one back together, clean the inside of the plenum( clean the root of the weld) and continue through out.
Idea 4: i am curious when i go to tune to see if i can change the rpm level for the butterflies to open. say i hit boost at 4200 rpm, i would have them open right there to keep low end up there.
Cloudasc Idea: Centralize the Throttle body to create even air flow.
sorry guys but i am at work so i will be putting more ideas up on break but pleas throw any suggestions out there. thanks
