im in the process of building. a f22b dohc head on a f22a6 i have je 12.5:1 forged pistons and i have bored it out to 86mm a p14 comp aem full length cold air with a msd external blaster series 2 coil dc sport header and high flow cat along with apexi cat back and obx 10.5mm plug wires and i have done away with my ac/ and ps. can any one give me an estamite on the hp i might have ay the crank, this engine should be back together by the end of the week if the machine shop would hurry up with my block and i will dyno the damn thing and give a post
12.5:1 compression
delta regrind 272 cams(h23), some adjustable cam gears. That get you some nice power. I'd like to see this go against a h22Originally posted by 12.5:1thought so some fuck head and me were arguing over it earlier, what are some other thins that i could do to significantly raise my hp on a small budgetShift_BOOST
BOOM!
do you mean that it wont idle with the stock cams or the aggresive ones and what type of head work did you have in mind please give details this is my first all out build and i want it to be the shit, ive built 3 d15bseries but just pretty much rering thats all, were can i find aftermarket f22b dohc cams or am i just gonna have to have the stock ones reground, help me out if you can guysOriginally posted by J-specCb4with that kind of compression id say u should do some head work and really aggressive cams it may not idle when ur done but it will ripLast edited by HondaFan81; 03-20-2006, 12:03 AM.
budget of now more than $1500 thats about all i have to work withOriginally posted by J-specCb4with that kind of compression id say u should do some head work and really aggressive cams it may not idle when ur done but it will rip[/QUOTE do you mean that it wont idle with the stock cams or the aggresive ones and what type of head work did you have in mind please give details this is my first all out build and i want it to be the shit, ive built 3 d15bseries but just pretty much rering thats all, were can i find aftermarket f22b dohc cams or am i just gonna have to have the stock ones reground, help me out if you can guysLast edited by HondaFan81; 03-20-2006, 12:04 AM.
