Bottom End Rebuild Help
    So after a year and a half I am (hopefully) finally getting another cb7. She's a green 93 (I think LX) two door with oem fat 5 spoke rims.
    I already have a daily and am thinking about redoing everything on this car because I want to.
    ​​​​​​​I want to rebuild the engine but don't know what to get. I found full engine rebuild kits for 300ish but I doubt they are any good.
    What should I buy? Should I do any performance upgrades while I'm redoing the bottom end?
    Im trying to keep it as cheap as possible while still getting good parts.
    Does anyone else have a monthly budget of 10mm sockets or is it just me?
    First, set and/or figure out what you want your end goal to be. Then, proceed from there. Right now, it seems as if you're just shooting in the dark with no specific target in mind. Pick something specific to aim at.
    The Lord watches over me!
    - D. Chappelle
      Also take cheap out of the equation. If you are building it, then you want turbo / power. If you want turbo power you want a reliable car as well. Fast + reliable doesn't happen long with cheap.
      Most decisions you run into (ie: should I buy this turbo manifold or that one) you'll decide for the expensive one. It's reliable, the tuner suggests it, it breaks less, leaks less, and probably looks better (shiny). But as StraightSuccess mentioned, first determine your HP goal. If you have not driven a 300HP car, make sure you do before deciding. or 400HP, sometimes there's a comfort limit of HP people want. & faster doesn't always mean better.
      Cheers
        Im looking to make it reliable. I am not looking to do a turbo build, thats just out of my ballpark. I dont need to be making big numbers, Im just looking to make the engine good and reliable and want to know what i should put into the engine while im in there.
          Order all OEM Honda components then. They should be able to be had for a non-bank-account-breaking type of build. Your dealer may even give you a deal/discount as the parts are probably sitting around collecting dust in some national distribution warehouse.
          - D. Chappelle
            Awesome, so just good ol OEM Honda stuff. Easy. I usually use Fel-Pro for all my gaskets. Is Honda OEM better than Fel-Pro or should the Fel-Pro gasket kits be just fine?
              Can anyone think of any OEM parts he would avoid? (Ie: H22 timing belt tensioner)
                Thanks for all your input. I checked out the car today and bought it. The car has 260,000 miles but drives amazing. I dont actually know if ill be doing a bottom end rebuild. Should I only do it if its needed?
                  Yep, only if needed.
