Lots of questions...I'm putting them in "quote" form to make it easier...
Here's the story.
ok I'm going to wait on the super cup kit (neuspeed koni yellows (springs/shocks))...but I need new ball joints and an alignment NOW...too much negative camber eating my inner tires.
I'm guessing my springs are sagging a little, but I'm sure the ball joints aren't helping.
I am looking into ball joints right now, and I've decided to not replace the whole upper control arm. I will replace just the ball joint, as i have found several "upper ball joint" only parts.
And...if that's the case,
G-man informs me that neuspeeds koni yellows setup will give me a pretty good drop...
Here's the story.
Question 1
So, should I buy an adjustable ball joint to go in the upper control arm (front) or should I get a regular ball joint for the front? Then, once I DO get the new shocks/springs, buy an ingalls camber adjusting kit?
Question 2
What is your experience with the adjustable ball joints vs ingalls style camber correction kit (control arm anchor bolt style)
Question 3
Also, for the rears, is it possible to replace JUST the ball joints or do the only sell the whole arm.
question 4
won't I need something to adjust the rear camber as well once I buy this setup?
Question 5
So when I do get the koni's, will I need 1.5 degree +- camber correcting parts or a 3 degree?
__
