Alignment Results
    Alignment Results
    Well I have needed to get my alignment checked for a while. So I did.
    It isn't too bad, but does need attention soon.
    Here goes.
    Front Left
    Camber -1.0
    Caster 1.0
    Toe -0.23
    Front Right
    Camber -0.9
    Caster 1.0
    Toe -0.12
    Rear Left
    Camber -0.7
    Toe -0.15
    Rear Right
    Camber -0.6
    Toe 0.09
    Total Toe -0.05
    Thrust Angle -0.12
    It was done on a Hunter Machine.
    I need Upper ball joints on both sides,
    and a tie rod end on my driver side.
    Now all i need are suggestions on what is good to use.
    Firestone said Napa (Of course) for an adjustable Ball joint kit
    and i don't know what to look for in a good tie rod end.
    Should i get 2 new tie rod ends to just get i done?
    Im going to search around for some info right now and see whats out there.
    I wouldn't worry about a camber kit just yet. You aren't even that low.
    Buy the tie rods from tasauto.com They're pretty cheap.
      I know i don't need a kit. I need adjustable ball joints. And i might end up trading my Motegis for a drop.
        Isnt adjustable balljoints same as a camber kit? Correct me if i'm wrong
        1993 Accord LX - Sold
        93 BMW 525it - SOLD
        92 Accord EX Sedan - SOLD
        2000 Accord Coupe - Traded-In
        2003 Accord V6 6spd Coupe - Sold
        2001 Honda Civic Ex - SOLD
        2013 Chevy Traverse LTZ - Kid hauler
        2003 Acura Tl 3.2 - Daily Commuter
          No your not. Im a noob tot he whole suspension thing. i actually found the ones im going to get and realized they were the same thing
          But im going to drop it soon. And im not going to buy some ball joints just to get some more later.
            1 degree of camber won't do anything. I have much more than that and I notice no shoulder wear.
            But, your toe is kinda off.
            Gary A.K.A. Carter
            [sig killed by photobucket]
              just woundering, how low are you?
              http://www.cb7tuner.com/vbb/showthread.php?t=91030 <--MY RIDE!
              http://www.cb7tuner.com/vbb/showthread.php?t=140230 <--MY ongoing ENGINE BUILD!..
                im not. im stock all around. but i have a drop coming soon and i don't want to spend money on new ball joints and then drop and need more.
                I found SPC joints for $95
                  ^ where at ?
                    Originally posted by 8ball View Post
                    ^ where at ?
                    Ebay brotha.
                      Go ahead and get the SPC balljoints if you plan on lowering. Might as well if you have the money.
                      Originally posted by Maple50175
                      Oh here we go again. Maples other half.
                        spend the money now on the right part and you wont have to replace anything later
                          Ebay brotha.
                          I think that price is for one spc ball joint only. Double check it with the seller before you commit yourself.
                            fix thrust angle, that will cause a pull. i like to toe out in the front for better turn in.
