ok so i noticed when im driving and when i start braking my car makes a creeking noise almost like rubbing when i and it scares me some times not sure what this is. it started this after i painted my wheels a camo green
suspension problems
You didn't paint them on the car did you? Could be ball joints/bushings/springs/shocks/sway bar/tie rods or paint over spray somewhere it shouldn't be. Lift it up and move things around until you find the source of the noise. USE JACK STANDS!
1993 SE Coupe MRT - 1992 LX Sedan MRT
93 Accord SE Bose Stereo MYTHS & FACTS - F22A* Power Plant Removal(UNDER CONSTRUCTION)
Ok on the passenger side the caliper is the only thing with green on it. And my outer tie rod was a lil loose so I tightend it up now off to driver sideOriginally posted by wildBill83 View PostYou didn't paint them on the car did you? Could be ball joints/bushings/springs/shocks/sway bar/tie rods or paint over spray somewhere it shouldn't be. Lift it up and move things around until you find the source of the noise. USE JACK STANDS!
MRTvvv
