Hey guys so I am planning on racing autocross and I am playing with my spring rates. I already have the kit that Ground control sends you (350f/300R) with Koni yellows and progress rear sway bar combined with Megan racing camber and toe arms...so I have the supporting mods, well mostly.
I am planning on buying 400 ft/lbs for the front, and putting the rear on the 350 ft/lb springs that are now in the front. I believe that it will track about the same with a hint of over steer and very little under steer. I am just trying to limit my roll with the slightly upgraded Spring rates. What do you guys think?
I am 99.9% sure that the koni's can handle the rates and won't have an issue with underdamping the springs but won't know unless I do it or another member on here has run similar suspension.
